18820 messages
Le 01 Février 2008 à 18h45
litsgu
49 messages
Le 01 Février 2008 à 19h23
YOP
18820 messages
Le 01 Février 2008 à 19h46
Il est parfois nécessaire de faire plusieurs passes avec Vundo
Si ça ne va pas on les aura autrement....
litsgu
49 messages
Le 01 Février 2008 à 20h57
bon voila les rapport mais antivir s'affole je ne peux meme plus jouer a mes jeux tranqilement aide moi stp sa me tue fff:
RAPPORT VUNDOFIX:
VundoFix V6.7.7
Checking Java version...
Sun Java not detected
Scan started at 20:33:39 01/02/2008
Listing files found while scanning....
C:\Program Files\Fichiers communs\Mediafour\MacDriveiTunesPatch.dll
C:\windows\system32\gjjlm.ini
C:\windows\system32\gjjlm.ini2
C:\windows\system32\mljjg.dll
Beginning removal...
Attempting to delete C:\Program Files\Fichiers communs\Mediafour\MacDriveiTunesPatch.dll
C:\Program Files\Fichiers communs\Mediafour\MacDriveiTunesPatch.dll Has been deleted!
Attempting to delete C:\windows\system32\gjjlm.ini
C:\windows\system32\gjjlm.ini Has been deleted!
Attempting to delete C:\windows\system32\gjjlm.ini2
C:\windows\system32\gjjlm.ini2 Has been deleted!
Attempting to delete C:\windows\system32\mljjg.dll
C:\windows\system32\mljjg.dll Has been deleted!
Performing Repairs to the registry.
Done!
Pourquoi il ne trouve plus byxurol alors que antivir le detecte ensenoir:
RAPPORT VBG:
[02/01/2008, 20:42:28] - VirtumundoBeGone v1.5 ( "C:\Documents and Settings\Gulli\Bureau\VirtumundoBeGone.exe" )
[02/01/2008, 20:42:34] - Detected System Information:
[02/01/2008, 20:42:34] - Windows Version: 5.1.2600, Service Pack 1
[02/01/2008, 20:42:34] - Current Username: Gulli (Admin)
[02/01/2008, 20:42:34] - Windows is in NORMAL mode.
[02/01/2008, 20:42:34] - Searching for Browser Helper Objects:
[02/01/2008, 20:42:34] - BHO 1: {031AA453-5089-4716-9A0E-5E57EED49280} ()
[02/01/2008, 20:42:34] - WARNING: BHO has no default name. Checking for Winlogon reference.
[02/01/2008, 20:42:34] - No filename found. Continuing.
[02/01/2008, 20:42:34] - BHO 2: {4E9A0766-A344-4D96-839F-404188091627} ()
[02/01/2008, 20:42:34] - BHO 3: {56992BFB-46B5-4738-863A-5C45FEA0AEE1} ()
[02/01/2008, 20:42:34] - Checking for HKLM\...\Winlogon\Notify\mllji
[02/01/2008, 20:42:34] - Key not found: HKLM\...\Winlogon\Notify\mllji, continuing.
[02/01/2008, 20:42:34] - BHO 4: {67EDE3EB-3C04-4294-958A-9893A7DC5D59} ()
[02/01/2008, 20:42:34] - BHO 5: {8739811D-32B3-4A00-8012-AA50C8354593} ()
[02/01/2008, 20:42:34] - Checking for HKLM\...\Winlogon\Notify\mljjg
[02/01/2008, 20:42:34] - Key not found: HKLM\...\Winlogon\Notify\mljjg, continuing.
[02/01/2008, 20:42:34] - BHO 6: {8C6291BA-326A-489E-8BB4-05170BB1D1A3} ()
[02/01/2008, 20:42:34] - Checking for HKLM\...\Winlogon\Notify\mllmn
[02/01/2008, 20:42:34] - Key not found: HKLM\...\Winlogon\Notify\mllmn, continuing.
[02/01/2008, 20:42:34] - BHO 7: {98663E21-9CCE-4CF6-863C-911A9523A66F} ()
[02/01/2008, 20:42:34] - Checking for HKLM\...\Winlogon\Notify\byxurol
[02/01/2008, 20:42:34] - Key not found: HKLM\...\Winlogon\Notify\byxurol, continuing.
[02/01/2008, 20:42:34] - BHO 8: {99BB910B-878D-4A89-9AEA-83D118467B38} ()
[02/01/2008, 20:42:34] - BHO 9: {A1BD936F-923E-453D-96E8-278EF3D5C9A0} ()
[02/01/2008, 20:42:34] - Finished Searching Browser Helper Objects
[02/01/2008, 20:42:34] - Finishing up...
[02/01/2008, 20:42:34] - Nothing found! Exiting... ensenoir:
RAPPORT FIX VUNDO DE SYMANTEC:
Symantec Trojan.Vundo Removal Tool 1.5.0
C:\System Volume Information: (not scanned)
E:\System Volume Information: (not scanned)
Trojan.Vundo has not been found on your computer.
:argh: :argh:
Ils se foutent de ma guel ils osent dire que mon pc est cleen
litsgu
49 messages
Le 01 Février 2008 à 20h58
remarque: internet explorer est infecter quand je le lance ou clique sur des lien antir detect des truc en htlm
18820 messages
Le 02 Février 2008 à 10h06
petite mise au point sur certaines chose:
Code je ne peux meme plus jouer a mes jeux
Tant que ton ordi n'est pas clean, tu aura des soucis. Je ne te conseille pas de jouer pour le moment. Un Pc contaminé est un PC en danger, si tu désire venir à bout de ton infection, tu dois prendre patience et faire les choses dans un certain ordre logique.
Code Il sera clean quand je t'aurai dit que ton pc est clean, en fin de procédure, soit patient, sinon tu va faire pire que mieux.
D'autres part n'essayes pas de faire des procédures qui ne sont pas proposées ici (risque de passer au-dessus de certaines infections )
On reste calme:
Citation Ils se foutent de ma guel ils osent dire que mon pc est cleen
Sache que ce sont des outils spécifiques, pour une infection ciblée (Vundo ), dans ce cas ce sont des outils qui ont besoin de mise à jour, mais les auteurs de ces fix doivent être mis au courant des nouvelles variantes au jour le jour....et parfois, la mise à jour est un peu dépassée par rapport au temps réel.
Bien, ceci étant précisé, fais ceci:
* Ferme/Désactive ton antivirus (important), avant de télécharger et lancer Combofix.
* Télécharge combofix.exe (par sUBs) sur ton Bureau : http://download.bleepingcomputer.com/sUBs/ComboFix.exe
* Double clique combofix.exe et suis les invites.
* Ne pas cliquer sur la fenetre de commande de Combofix pendant le scan, cela peut perturber l'outil.
* Lorsque le scan sera complété, un rapport apparaîtra. Copie/colle ce rapport dans ta prochaine réponse.
litsgu
49 messages
Le 02 Février 2008 à 16h40
lol toute la journé je peu rien faire a par jouer et tu me dit que je peut pas jouer.... j'vais casser ma machine je croi
Bonjour Winx merci pour ta patience tien je te donne le rapport de combofix:
ComboFix 08-02.02.5 - Gulli 2008-02-02 16:31:08.1 - NTFSx86
Microsoft Windows XP Professionnel 5.1.2600.1.1252.1.1036.18.1662 [GMT 1:00]
Endroit: C:\Documents and Settings\Gulli\Bureau\ComboFix.exe
* Création d'un nouveau point de restauration
AVERTISSEMENT - LA CONSOLE DE RÉCUPÉRATION N'EST PAS INSTALLÉE SUR CETTE MACHINE !!
(((((((((((((((((((((((((((((((((((( Autres suppressions ))))))))))))))))))))))))))))))))))))))))))))))))
C:\WINDOWS\system32\pac.txt
((((((((((((((((((((((((((((( Fichiers cr‚‚s 2008-01-02 to 2008-02-02 ))))))))))))))))))))))))))))))))))))
2008-02-01 16:42 . 2008-02-01 16:42 <REP> d-------- C:\Documents and Settings\All Users\Application Data\MailFrontier
2008-02-01 16:41 . 2008-02-01 18:02 <REP> d-------- C:\WINDOWS\system32\ZoneLabs
2008-02-01 16:41 . 2008-02-01 16:41 <REP> d-------- C:\Program Files\Zone Labs
2008-02-01 16:41 . 2007-06-21 21:54 1,086,952 --a------ C:\WINDOWS\system32\zpeng24.dll
2008-02-01 16:41 . 2008-02-02 16:11 58,727 --a------ C:\WINDOWS\system32\vsconfig.xml
2008-02-01 16:08 . 2008-02-01 16:08 <REP> d-------- C:\Program Files\Avira
2008-02-01 16:08 . 2008-02-01 16:08 <REP> d-------- C:\Documents and Settings\All Users\Application Data\Avira
2008-01-31 22:14 . 2008-02-01 20:38 <REP> d-------- C:\Program Files\Fichiers communs\Mediafour
2008-01-31 22:08 . 2008-01-31 22:08 277,352 -ra------ C:\WINDOWS\system32\drivers\MDFSYSNT.SYS
2008-01-31 22:08 . 2008-01-31 22:08 44,404 -ra------ C:\WINDOWS\system32\drivers\MDPMGRNT.SYS
2008-01-31 22:07 . 2008-01-31 22:07 86,016 -ra------ C:\WINDOWS\system32\MACDRAPI.DLL
2008-01-31 22:06 . 2008-01-31 22:06 139,264 -ra------ C:\WINDOWS\system32\MDPROPS2.CPL
2008-01-31 22:00 . 2008-01-31 22:17 <REP> d-------- C:\Program Files\BitComet
2008-01-31 22:00 . 2008-01-31 22:02 <REP> d-------- C:\Downloads
2008-01-31 21:58 . 2008-01-31 21:58 <REP> d-------- C:\Program Files\Azureus
2008-01-31 19:54 . 2008-02-02 01:43 <REP> d-------- C:\VundoFix Backups
2008-01-31 15:43 . 2008-01-31 15:47 <REP> d-------- C:\Program Files\Navilog1
2008-01-30 22:00 . 2008-01-30 22:00 166 --a------ C:\key.shm
2008-01-30 20:58 . 2008-01-30 20:58 <REP> d-------- C:\Documents and Settings\Gulli\Application Data\Grisoft
2008-01-30 20:58 . 2008-01-30 20:58 <REP> d-------- C:\Documents and Settings\All Users\Application Data\Grisoft
2008-01-30 20:58 . 2007-05-30 13:10 10,872 --a------ C:\WINDOWS\system32\drivers\AvgAsCln.sys
2008-01-30 20:11 . 2008-02-01 20:39 4,212 ---h----- C:\WINDOWS\system32\zllictbl.dat
2008-01-30 20:10 . 2008-02-02 16:35 <REP> d-------- C:\WINDOWS\Internet Logs
2008-01-30 15:31 . 2008-01-30 15:31 <REP> d-------- C:\Program Files\Trend Micro
2008-01-29 23:28 . 2008-01-30 22:40 <REP> d-------- C:\Documents and Settings\All Users\Application Data\Lavasoft
2008-01-29 23:26 . 2008-01-29 23:26 <REP> d-------- C:\Program Files\CCleaner
2008-01-29 22:59 . 2008-01-30 21:03 <REP> d-------- C:\Documents and Settings\All Users\Application Data\Spybot - Search & Destroy
2008-01-29 22:47 . 2004-10-07 13:39 89,088 --a------ C:\WINDOWS\system32\atl71.dll
2008-01-29 22:47 . 2001-03-08 18:30 24,064 --a------ C:\WINDOWS\system32\msxml3a.dll
2008-01-29 22:35 . 2008-01-29 23:40 <REP> d-------- C:\WINDOWS\system32\uwcee9
2008-01-29 22:35 . 2008-02-01 20:36 <REP> d-------- C:\WINDOWS\system32\nGpxx01
2008-01-29 22:35 . 2008-01-29 22:35 <REP> d-------- C:\WINDOWS\system32\aee1
2008-01-29 20:24 . 2008-02-01 23:27 22,328 --a------ C:\WINDOWS\system32\drivers\PnkBstrK.sys
2008-01-29 20:23 . 2008-02-01 23:26 103,736 --a------ C:\WINDOWS\system32\PnkBstrB.exe
2008-01-29 20:23 . 2008-01-29 20:23 66,872 --a------ C:\WINDOWS\system32\PnkBstrA.exe
2008-01-29 18:57 . 2008-01-29 18:57 <REP> d-------- C:\Program Files\id Software
2008-01-28 18:52 . 2008-01-28 18:52 25,280 --a------ C:\WINDOWS\system32\drivers\hamachi.sys
2008-01-28 16:51 . 2008-01-28 16:51 <REP> d----c--- C:\WINDOWS\system32\DRVSTORE
2008-01-28 16:51 . 2008-01-28 16:51 <REP> d-------- C:\WINDOWS\system32\AGEIA
2008-01-28 16:51 . 2008-01-30 22:40 <REP> d-------- C:\Program Files\Fichiers communs\Wise Installation Wizard
2008-01-28 16:51 . 2008-01-28 16:51 <REP> d-------- C:\Program Files\AGEIA Technologies
2008-01-28 16:47 . 2008-01-28 16:47 <REP> d-------- C:\Program Files\Alcohol Soft
2008-01-26 18:50 . 2008-01-31 22:14 <REP> d-------- C:\Program Files\Mediafour
2008-01-24 20:30 . 2008-01-24 20:30 <REP> dr-h----- C:\Documents and Settings\Gulli\Application Data\SecuROM
2008-01-24 20:30 . 2008-01-24 20:30 107,888 --a------ C:\WINDOWS\system32\CmdLineExt.dll
2008-01-24 00:40 . 2008-01-24 00:40 <REP> d-------- C:\Documents and Settings\Gulli\Application Data\MSN6
2008-01-24 00:40 . 2008-01-24 00:40 <REP> d-------- C:\Documents and Settings\All Users\Application Data\MSN6
2008-01-23 18:38 . 2008-01-29 22:18 <REP> d-------- C:\Documents and Settings\Gulli\Application Data\Hamachi
2008-01-23 16:30 . 2008-01-23 16:30 318 --a------ C:\WINDOWS\game.ini
2008-01-23 16:14 . 2008-01-23 16:14 <REP> d--hs---- C:\WINDOWS\ftpcache
2008-01-22 18:27 . 2008-01-22 18:27 <REP> d-------- C:\WINDOWS\system32\LogFiles
2008-01-22 18:27 . 2007-07-19 18:14 3,727,720 --a------ C:\WINDOWS\system32\d3dx9_35.dll
2008-01-22 18:27 . 2007-05-16 16:45 3,497,832 --a------ C:\WINDOWS\system32\d3dx9_34.dll
2008-01-22 18:27 . 2007-07-19 18:14 1,358,192 --a------ C:\WINDOWS\system32\D3DCompiler_35.dll
2008-01-22 18:27 . 2007-05-16 16:45 1,124,720 --a------ C:\WINDOWS\system32\D3DCompiler_34.dll
2008-01-22 18:27 . 2007-07-19 18:14 444,776 --a------ C:\WINDOWS\system32\d3dx10_35.dll
2008-01-22 18:27 . 2007-05-16 16:45 443,752 --a------ C:\WINDOWS\system32\d3dx10_34.dll
2008-01-22 18:27 . 2007-04-04 18:53 81,768 --a------ C:\WINDOWS\system32\xinput1_3.dll
2008-01-22 18:27 . 2008-01-24 21:20 22,328 --a------ C:\Documents and Settings\Gulli\Application Data\PnkBstrK.sys
2008-01-22 13:50 . 2008-01-22 13:58 <REP> d-------- C:\WINDOWS\system32\NtmsData
2008-01-21 15:57 . 2008-01-21 15:58 <REP> d-------- C:\Program Files\Analog Devices
2008-01-21 15:57 . 2001-09-19 05:47 765,952 -ra------ C:\WINDOWS\system\crlds3d.dll
2008-01-21 15:57 . 2006-03-17 10:18 392,960 -ra------ C:\WINDOWS\system32\drivers\senfilt.sys
2008-01-21 15:57 . 2007-01-16 02:09 293,888 -ra------ C:\WINDOWS\system32\drivers\ADIHdAud.sys
2008-01-21 15:57 . 2006-08-06 23:57 93,952 -ra------ C:\WINDOWS\system32\drivers\aeaudio.sys
2008-01-21 15:57 . 2006-06-30 08:00 28,160 -ra------ C:\WINDOWS\system32\PostProc.dll
2008-01-21 15:57 . 2001-08-23 17:47 22,016 --a------ C:\WINDOWS\system32\wdmaud.drv
2008-01-21 14:03 . 2004-03-17 14:36 15,872 --a------ C:\WINDOWS\system32\spupdsvc.exe
2008-01-20 08:07 . 2008-01-20 08:07 33,292 --a------ C:\WINDOWS\system32\drivers\scdemu.sys
2008-02-02 15:35 15,410,691 ----a-w C:\WINDOWS\Internet Logs\vsmon_on_demand_2008_02_02_16_34_14_full.dmp.zip
2008-02-01 15:44 14,368 --sha-w C:\WINDOWS\system32\drivers\fidbox.dat
2008-02-01 15:44 1,824 --sha-w C:\WINDOWS\system32\drivers\fidbox2.dat
2008-02-01 15:44 1,244 --sha-w C:\WINDOWS\system32\drivers\fidbox2.idx
2008-02-01 15:44 1,244 --sha-w C:\WINDOWS\system32\drivers\fidbox.idx
2008-02-01 15:42 75,932 ----a-w C:\WINDOWS\system32\drivers\klick.dat
2008-02-01 15:42 74,396 ----a-w C:\WINDOWS\system32\drivers\klin.dat
2008-01-31 21:20 --------- d--h--w C:\Program Files\InstallShield Installation Information
2008-01-29 15:06 163,644 ----a-w C:\WINDOWS\system32\drivers\secdrv.sys
2008-01-21 12:13 715,248 ----a-w C:\WINDOWS\system32\drivers\sptd.sys
2008-01-21 12:09 --------- d-----w C:\Program Files\Alwil Software
2008-01-21 12:02 --------- d-----w C:\Program Files\Inventel
2008-01-21 11:48 --------- d-----w C:\Program Files\Fichiers communs\InstallShield
2008-01-21 11:22 558,142 ----a-w C:\WINDOWS\java\Packages\D3HRRV3L.ZIP
2008-01-21 11:22 155,995 ----a-w C:\WINDOWS\java\Packages\HNFH7BT3.ZIP
2008-01-21 11:22 --------- d-----w C:\Program Files\microsoft frontpage
2008-01-21 11:21 --------- d-----w C:\Program Files\Fichiers communs\MSSoap
2008-01-21 11:20 --------- d-----w C:\Program Files\Services en ligne
2008-01-21 11:16 --------- d-----w C:\Program Files\Fichiers communs\SpeechEngines
2008-01-21 11:16 --------- d-----w C:\Program Files\Fichiers communs\ODBC
2007-12-05 00:41 7,435,392 ----a-w C:\WINDOWS\system32\drivers\nv4_mini.sys
((((((((((((((((((((((((((((((((( Point de chargement Reg )))))))))))))))))))))))))))))))))))))))))))))))))
REGEDIT4
*Note* les ‚l‚ments vides & les ‚l‚ments initiaux l‚gitimes ne sont pas list‚s
[HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{031AA453-5089-4716-9A0E-5E57EED49280}]
[HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{4E9A0766-A344-4D96-839F-404188091627}]
[HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{56992BFB-46B5-4738-863A-5C45FEA0AEE1}]
C:\WINDOWS\System32\mllji.dll
[HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{67EDE3EB-3C04-4294-958A-9893A7DC5D59}]
[HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{8739811D-32B3-4A00-8012-AA50C8354593}]
C:\WINDOWS\System32\mljjg.dll
[HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{8C6291BA-326A-489E-8BB4-05170BB1D1A3}]
C:\WINDOWS\System32\mllmn.dll
[HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{99BB910B-878D-4A89-9AEA-83D118467B38}]
[HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{A1BD936F-923E-453D-96E8-278EF3D5C9A0}]
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\explorer\shelliconoverla yidentifiers\{A08FB30D-51C4-4E54-AA5E-FF18739802EA}]
@=Mediafour Mac Volume Icons
"CTFMON.EXE"="C:\WINDOWS\System32\ctfmon.exe" [2002-08-29 11:45 13312]
"AlcoholAutomount"="C:\Program Files\Alcohol Soft\Alcohol 120\axcmd.exe" [2007-12-22 08:20 222080]
"NvCplDaemon"="C:\WINDOWS\System32\NvCpl.dll" [2007-12-05 01:41 8523776]
"nwiz"="nwiz.exe" [2007-12-05 01:41 1626112 C:\WINDOWS\system32\nwiz.exe]
"NvMediaCenter"="C:\WINDOWS\System32\NvMcTray.dll" [2007-12-05 01:41 81920]
"SoundMAXPnP"="C:\Program Files\Analog Devices\Core\smax4pnp.exe" [2006-12-18 14:34 868352]
"SoundMAX"="C:\Program Files\Analog Devices\SoundMAX\Smax4.exe" [2006-07-13 07:12 729088]
"PWRISOVM.EXE"="E:\Programe Files\PowerISO\PWRISOVM.EXE" [2008-01-20 08:05 217088]
"!AVG Anti-Spyware"="C:\Program Files\Grisoft\AVG Anti-Spyware 7.5\avgas.exe" [2007-06-11 10:25 6731312]
"MDDiskProtect.exe"="C:\Program Files\Mediafour\MacDrive\MDDiskProtect.exe" [2008-01-31 22:08 94208]
"MediafourGettingStartedWithMacDrive6"="C:\Program Files\Mediafour\MacDrive\MacDrive.exe" [2008-01-31 22:07 86016]
"Mediafour Mac Volume Notifications"="C:\Program Files\Fichiers communs\Mediafour\MACVNTFY.exe" [2008-01-31 22:08 61440]
"avgnt"="C:\Program Files\Avira\AntiVir PersonalEdition Classic\avgnt.exe" [2008-02-01 16:40 249896]
"ZoneAlarm Client"="C:\Program Files\Zone Labs\ZoneAlarm\zlclient.exe" [2007-06-21 21:54 919016]
[HKEY_USERS\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Run]
"CTFMON.EXE"="C:\WINDOWS\System32\CTFMON.EXE" [2002-08-29 11:45 13312]
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\MacDrive-iTunes compatibility]
*Newly Created Service* - ALG
Contenu du dossier 'Scheduled Tasks/Tƒches planifi‚es'
"2008-02-01 23:00:00 C:\WINDOWS\Tasks\At1.job"
- C:\WINDOWS\System32\47UkM15h.exe
"2008-01-29 21:30:23 C:\WINDOWS\Tasks\At10.job"
"2008-01-29 21:30:23 C:\WINDOWS\Tasks\At11.job"
"2008-01-29 21:30:23 C:\WINDOWS\Tasks\At12.job"
"2008-01-29 21:30:23 C:\WINDOWS\Tasks\At13.job"
"2008-01-29 21:30:23 C:\WINDOWS\Tasks\At14.job"
"2008-01-29 21:30:23 C:\WINDOWS\Tasks\At15.job"
"2008-01-29 21:30:23 C:\WINDOWS\Tasks\At16.job"
"2008-02-01 15:00:01 C:\WINDOWS\Tasks\At17.job"
"2008-02-01 16:02:22 C:\WINDOWS\Tasks\At18.job"
"2008-02-01 17:00:11 C:\WINDOWS\Tasks\At19.job"
"2008-02-02 00:00:00 C:\WINDOWS\Tasks\At2.job"
"2008-02-01 18:00:00 C:\WINDOWS\Tasks\At20.job"
"2008-02-01 19:00:00 C:\WINDOWS\Tasks\At21.job"
"2008-02-01 20:00:00 C:\WINDOWS\Tasks\At22.job"
"2008-02-01 21:00:00 C:\WINDOWS\Tasks\At23.job"
"2008-02-01 22:00:00 C:\WINDOWS\Tasks\At24.job"
"2008-02-02 01:00:00 C:\WINDOWS\Tasks\At3.job"
"2008-02-02 02:00:00 C:\WINDOWS\Tasks\At4.job"
"2008-01-30 03:00:02 C:\WINDOWS\Tasks\At5.job"
"2008-01-29 21:30:23 C:\WINDOWS\Tasks\At6.job"
"2008-01-29 21:30:23 C:\WINDOWS\Tasks\At7.job"
"2008-01-29 21:30:23 C:\WINDOWS\Tasks\At8.job"
"2008-01-29 21:30:23 C:\WINDOWS\Tasks\At9.job"
catchme 0.3.1344 W2K/XP/Vista - rootkit/stealth malware detector by Gmer, http://www.gmer.net
Rootkit scan 2008-02-02 16:35:03
Windows 5.1.2600 Service Pack 1 NTFS
Balayage processus cach‚s ...
Balayage cach‚ autostart entries ...
Balayage des fichiers cach‚s ...
Scan termin‚ avec succ¦s
Les fichiers cach‚s: 0
------------------------ Other Running Processes ------------------------
C:\WINDOWS\System32\RUNDLL32.EXE
C:\Program Files\Avira\AntiVir PersonalEdition Classic\avguard.exe
C:\Program Files\Avira\AntiVir PersonalEdition Classic\sched.exe
C:\WINDOWS\System32\nvsvc32.exe
C:\WINDOWS\System32\PnkBstrA.exe
C:\Program Files\Alcohol Soft\Alcohol 120\StarWind\StarWindServiceAE.exe
Temps d'accomplissement: 2008-02-02 16:35:56 - machine was rebooted
ComboFix-quarantined-files.txt 2008-02-02 15:35:39
Allé a plus ( j'veux pas t'embeter mais en tout cas moi toute les 10 min jvai passer sur le forum car je suis déseperé )
18820 messages
Le 02 Février 2008 à 19h11
fais ceci:
Démarrer/Exécuter/taper REGSVR32 /u byxurol.dll
relances Vundofix.exe
Dans la fenêtre blanche, fais un clic droit...
Tu as le menu "Add more files?" qui s'affiche, mets toi dessus..
copie le chemin dans la fenêtre suivante:
C:\WINDOWS\system32\byxurol.dll
ensuite fais remove Vundo
ensuite fais ceci:
Fais cette procédure, postes le rapport généré sur le forum.
litsgu
49 messages
Le 02 Février 2008 à 19h26
Sa m'a l'air pas mal :
fais ceci:
il m'a dit: load library ( byxurol) a echoué Le module spécidié est introuvable.
RAPPORT VUNDOFIX :
Done!
c'est bien ou pas?
18820 messages
Le 02 Février 2008 à 19h31
disparu ?
byxurol.dll
Télécharge OAD http://sosvirus.changelog.fr/OAD.exe
- Enregistre le sur ton bureau
Double clique sur le OAD pour le lancer
- nom de fichier à rechercher tape ou fais un copier coller de : byxurol
- Type de recherche : sélectionne l'option 6 puis valide [entree]
OAD va maintenant rechercher le fichier. Laisse le travailler jusqu'à ce qu'il en ai terminé.
Le rapport de recherche s'affichera automatiquement à dès qu'il en aura terminé.
- Fais un copier / coller de ce rapport dans ton prochain post.
litsgu
49 messages
Le 02 Février 2008 à 19h42
02/02/2008 ---- 19:40:56,85
§§§§§§ [byxurol] §§§§§§
[X] Registre
-------------- [ ] rapide
-- Fichier --- [ ] disque systeme
------------- [X] complete
[Registre]
[HKEY_USERS\S-1-5-21-507921405-823518204-839522115-1003\Software\Microsoft\Windows\CurrentVersion\Explorer\RunMRU]
"a"="REGSVR32 /u byxurol.dll\\1"
[Fichier]
[Même date]
Aucun fichier créé à la même date détecté
Outil Aide Diagnostic By !aur3n7 Version 1.1
§§§§§ Fin Rapport §§§§§
litsgu
49 messages
Le 02 Février 2008 à 21h31
j'en suis pas sure mais je croi qu'il n'y a plus aucun virus sur le PC.
Je ne recois plus de message de antivir detectan vundo et son collegue byxurol.dll.
pourré tu me dire ce que je doit faire pour confirmé tout sa stp.
synthexe
2498 messages
Le 03 Février 2008 à 13h09
Bonjour à tous les 2
Je me permet une intervention, car sUBs, le créateur de ComboFix souhaite que l'utilisation de son outil soit supervisé par quelqu'un de formé à son analyse et utilisation, voila donc ce qu'on va faire :
[*:5qt0l0bl]Crée un fichier avec le bloc-note, saisie le contenu de la boite ci-dessous :[/*:m:5qt0l0bl]
Code File::
Folder::
Registry::
[-HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{031AA453-5089-4716-9A0E-5E57EED49280}]
[-HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{4E9A0766-A344-4D96-839F-404188091627}]
[-HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{56992BFB-46B5-4738-863A-5C45FEA0AEE1}]
[-HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{67EDE3EB-3C04-4294-958A-9893A7DC5D59}]
[-HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{8739811D-32B3-4A00-8012-AA50C8354593}]
[-HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{8C6291BA-326A-489E-8BB4-05170BB1D1A3}]
[-HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{99BB910B-878D-4A89-9AEA-83D118467B38}]
[-HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{A1BD936F-923E-453D-96E8-278EF3D5C9A0}]
[*:5qt0l0bl]Sauvegarde le fichier avec le nom suivant : CFScript.txt[/*:m:5qt0l0bl]
[*:5qt0l0bl]Fait un glisser/déposer de ce fichier CFScript sur le fichier ComboFix.exe comme sur la capture
[/*:m:5qt0l0bl]
[*:5qt0l0bl]Une fenêtre bleue va apparaître: au message qui apparaît ( Type 1 to continue, or 2 to abort) , tape 1 puis valide.[/*:m:5qt0l0bl]
[*:5qt0l0bl]Patiente le temps du scan.Le bureau va disparaître à plusieurs reprises: c'est normal!
Ne touche à rien tant que le scan n'est pas terminé.[/*:m:5qt0l0bl]
[*:5qt0l0bl]Une fois le scan achevé, un rapport va s'afficher: poste son contenu.[/*:m:5qt0l0bl]
Bon dimanche à tous
litsgu
49 messages
Le 03 Février 2008 à 14h12
Salut synthexe merci de donné tes conseil je fait sa tout de suite.
litsgu
49 messages
Le 03 Février 2008 à 14h22
Bon par contre il ne m'a pa donné le choix de choisir entre l'option1 ou 2...
il a direct lancer son apllication tout seul alor était elle la bonne ?
ComboFix 08-02.02.5 - Gulli 2008-02-03 14:17:24.2 - NTFSx86
Microsoft Windows XP Professionnel 5.1.2600.1.1252.1.1036.18.1686 [GMT 1:00]
Command switches used :: C:\Documents and Settings\Gulli\Bureau\CFScript.txt
FILE
((((((((((((((((((((((((((((( Fichiers créés 2008-01-03 to 2008-02-03 ))))))))))))))))))))))))))))))))))))
2008-02-03 04:18 . 2008-02-03 04:18 <REP> d-------- C:\Program Files\Microsoft Games
2008-02-01 16:41 . 2008-02-03 14:13 58,727 --a------ C:\WINDOWS\system32\vsconfig.xml
2008-01-31 22:00 . 2008-02-03 02:58 <REP> d-------- C:\Downloads
2008-01-31 19:54 . 2008-02-02 19:21 <REP> d-------- C:\VundoFix Backups
2008-01-30 20:10 . 2008-02-03 03:29 <REP> d-------- C:\WINDOWS\Internet Logs
2008-01-29 20:24 . 2008-02-02 22:09 22,328 --a------ C:\WINDOWS\system32\drivers\PnkBstrK.sys
2008-01-29 20:23 . 2008-02-02 22:09 103,736 --a------ C:\WINDOWS\system32\PnkBstrB.exe
2008-02-03 03:46 --------- d-----w C:\Program Files\Fichiers communs\InstallShield
2008-02-03 01:06 --------- d--h--w C:\Program Files\InstallShield Installation Information
2007-12-05 01:53 356,352 ----a-w C:\WINDOWS\system32\NVUNINST.EXE
2007-12-05 00:41 81,920 ----a-w C:\WINDOWS\system32\nvwddi.dll
2007-12-05 00:41 81,920 ----a-w C:\WINDOWS\system32\nvmctray.dll
2007-12-05 00:41 8,523,776 ----a-w C:\WINDOWS\system32\nvcpl.dll
2007-12-05 00:41 753,664 ----a-w C:\WINDOWS\system32\nvcplui.exe
2007-12-05 00:41 6,901,760 ----a-w C:\WINDOWS\system32\nvoglnt.dll
2007-12-05 00:41 6,549,504 ----a-w C:\WINDOWS\system32\nvdisps.dll
2007-12-05 00:41 5,773,568 ----a-w C:\WINDOWS\system32\nv4_disp.dll
2007-12-05 00:41 5,611,520 ----a-w C:\WINDOWS\system32\nvdispsr.dll
2007-12-05 00:41 466,944 ----a-w C:\WINDOWS\system32\nvshell.dll
2007-12-05 00:41 458,752 ----a-w C:\WINDOWS\system32\nvmccssr.dll
2007-12-05 00:41 45,056 ----a-w C:\WINDOWS\system32\nvmccsrs.dll
2007-12-05 00:41 442,368 ----a-w C:\WINDOWS\system32\nvappbar.exe
2007-12-05 00:41 425,984 ----a-w C:\WINDOWS\system32\keystone.exe
2007-12-05 00:41 385,024 ----a-w C:\WINDOWS\system32\nvapi.dll
2007-12-05 00:41 356,352 ----a-w C:\WINDOWS\system32\nvudisp.exe
2007-12-05 00:41 35,328 ----a-w C:\WINDOWS\system32\nvcodins.dll
2007-12-05 00:41 35,328 ----a-w C:\WINDOWS\system32\nvcod.dll
2007-12-05 00:41 335,872 ----a-w C:\WINDOWS\system32\nvwrses.dll
2007-12-05 00:41 335,872 ----a-w C:\WINDOWS\system32\nvwrsel.dll
2007-12-05 00:41 327,680 ----a-w C:\WINDOWS\system32\nvwrsfr.dll
2007-12-05 00:41 327,680 ----a-w C:\WINDOWS\system32\nvwrsesm.dll
2007-12-05 00:41 327,680 ----a-w C:\WINDOWS\system32\nvrshe.dll
2007-12-05 00:41 327,680 ----a-w C:\WINDOWS\system32\nvrsar.dll
2007-12-05 00:41 323,584 ----a-w C:\WINDOWS\system32\nvwrspt.dll
2007-12-05 00:41 323,584 ----a-w C:\WINDOWS\system32\nvwrsit.dll
2007-12-05 00:41 319,488 ----a-w C:\WINDOWS\system32\nvwrsptb.dll
2007-12-05 00:41 319,488 ----a-w C:\WINDOWS\system32\nvwrsnl.dll
2007-12-05 00:41 315,392 ----a-w C:\WINDOWS\system32\nvwrsru.dll
2007-12-05 00:41 315,392 ----a-w C:\WINDOWS\system32\nvwrshu.dll
2007-12-05 00:41 311,296 ----a-w C:\WINDOWS\system32\nvwrsde.dll
2007-12-05 00:41 307,200 ----a-w C:\WINDOWS\system32\nvexpbar.dll
2007-12-05 00:41 303,104 ----a-w C:\WINDOWS\system32\nvwrstr.dll
2007-12-05 00:41 303,104 ----a-w C:\WINDOWS\system32\nvwrssl.dll
2007-12-05 00:41 303,104 ----a-w C:\WINDOWS\system32\nvwrsfi.dll
2007-12-05 00:41 3,715,072 ----a-w C:\WINDOWS\system32\nvvitvsr.dll
2007-12-05 00:41 3,710,976 ----a-w C:\WINDOWS\system32\nvvitvs.dll
2007-12-05 00:41 3,420,160 ----a-w C:\WINDOWS\system32\nvgames.dll
2007-12-05 00:41 3,334,144 ----a-w C:\WINDOWS\system32\nvgamesr.dll
2007-12-05 00:41 299,008 ----a-w C:\WINDOWS\system32\nvwrssk.dll
2007-12-05 00:41 299,008 ----a-w C:\WINDOWS\system32\nvwrsno.dll
2007-12-05 00:41 294,912 ----a-w C:\WINDOWS\system32\nvwrssv.dll
2007-12-05 00:41 294,912 ----a-w C:\WINDOWS\system32\nvwrspl.dll
2007-12-05 00:41 294,912 ----a-w C:\WINDOWS\system32\nvwrsda.dll
2007-12-05 00:41 290,816 ----a-w C:\WINDOWS\system32\nvwrsth.dll
2007-12-05 00:41 286,720 ----a-w C:\WINDOWS\system32\nvwrseng.dll
2007-12-05 00:41 286,720 ----a-w C:\WINDOWS\system32\nvwrscs.dll
2007-12-05 00:41 286,720 ----a-w C:\WINDOWS\system32\nvnt4cpl.dll
2007-12-05 00:41 282,624 ----a-w C:\WINDOWS\system32\nvwrsar.dll
2007-12-05 00:41 282,624 ----a-w C:\WINDOWS\system32\nvrsfr.dll
2007-12-05 00:41 282,624 ----a-w C:\WINDOWS\system32\nvrses.dll
2007-12-05 00:41 282,624 ----a-w C:\WINDOWS\system32\nvrsel.dll
2007-12-05 00:41 278,528 ----a-w C:\WINDOWS\system32\nvwrshe.dll
2007-12-05 00:41 278,528 ----a-w C:\WINDOWS\system32\nvrsit.dll
2007-12-05 00:41 278,528 ----a-w C:\WINDOWS\system32\nvrsde.dll
2007-12-05 00:41 274,432 ----a-w C:\WINDOWS\system32\nvrspt.dll
2007-12-05 00:41 274,432 ----a-w C:\WINDOWS\system32\nvrsnl.dll
2007-12-05 00:41 274,432 ----a-w C:\WINDOWS\system32\nvrsesm.dll
2007-12-05 00:41 270,336 ----a-w C:\WINDOWS\system32\nvrsru.dll
2007-12-05 00:41 266,240 ----a-w C:\WINDOWS\system32\nvrsptb.dll
2007-12-05 00:41 266,240 ----a-w C:\WINDOWS\system32\nvrsja.dll
2007-12-05 00:41 258,048 ----a-w C:\WINDOWS\system32\nvrstr.dll
2007-12-05 00:41 258,048 ----a-w C:\WINDOWS\system32\nvrssl.dll
2007-12-05 00:41 258,048 ----a-w C:\WINDOWS\system32\nvrssk.dll
2007-12-05 00:41 258,048 ----a-w C:\WINDOWS\system32\nvrsko.dll
2007-12-05 00:41 258,048 ----a-w C:\WINDOWS\system32\nvrshu.dll
2007-12-05 00:41 253,952 ----a-w C:\WINDOWS\system32\nvrsth.dll
2007-12-05 00:41 253,952 ----a-w C:\WINDOWS\system32\nvrssv.dll
2007-12-05 00:41 253,952 ----a-w C:\WINDOWS\system32\nvrspl.dll
2007-12-05 00:41 253,952 ----a-w C:\WINDOWS\system32\nvrsno.dll
2007-12-05 00:41 253,952 ----a-w C:\WINDOWS\system32\nvrsda.dll
2007-12-05 00:41 249,856 ----a-w C:\WINDOWS\system32\nvrsfi.dll
2007-12-05 00:41 249,856 ----a-w C:\WINDOWS\system32\nvrscs.dll
2007-12-05 00:41 245,760 ----a-w C:\WINDOWS\system32\nvrseng.dll
2007-12-05 00:41 229,376 ----a-w C:\WINDOWS\system32\nvmccs.dll
2007-12-05 00:41 225,280 ----a-w C:\WINDOWS\system32\nvrszhc.dll
2007-12-05 00:41 212,992 ----a-w C:\WINDOWS\system32\nvwrsja.dll
2007-12-05 00:41 2,854,912 ----a-w C:\WINDOWS\system32\nvmoblsr.dll
2007-12-05 00:41 2,519,040 ----a-w C:\WINDOWS\system32\nvwssr.dll
2007-12-05 00:41 2,498,560 ----a-w C:\WINDOWS\system32\nvwss.dll
REGEDIT4
*Note* les éléments vides & les éléments initiaux légitimes ne sont pas listés
R0 avgntmgr;avgntmgr;C:\WINDOWS\System32\DRIVERS\avgntmgr.sys [2007-07-18 14:22]
R0 MDPMGRNT;MDPMGRNT;C:\WINDOWS\System32\drivers\MDPMGRNT.sys [2008-01-31 22:08]
R1 avgntdd;avgntdd;C:\WINDOWS\System32\DRIVERS\avgntdd.sys [2007-08-09 13:04]
R1 MDFSYSNT;MDFSYSNT;C:\WINDOWS\System32\drivers\MDFSYSNT.sys [2008-01-31 22:08]
Rootkit scan 2008-02-03 14:18:43
Balayage processus cachés ...
Balayage caché autostart entries ...
Balayage des fichiers cachés ...
Scan terminé avec succès
Les fichiers cachés: 0
Temps d'accomplissement: 2008-02-03 14:18:57
ComboFix-quarantined-files.txt 2008-02-03 13:18:55
