Bonjour,j'aimerais avoir de l'aide
Java m'indique toujours un message d'erreur lors d'un démarrage d'une application pour envoyer mes photo en ligne(Jean Coutu).
Voici le message:
A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x6d0391ac, pid=6056, tid=5620
# JRE version: 6.0_17-b04
# Java VM: Java HotSpot(TM) Client VM (14.3-b01 mixed mode, sharing windows-x86 )
# Problematic frame:
# C [awt.dll+0x391ac]
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x02bbf800): JavaThread "AWT-Windows" daemon [_thread_in_native, id=5620, stack(0x02f50000,0x02fa0000)]
siginfo: ExceptionCode=0xc0000005, writing address 0xe59811c0
Registers:
EAX=0x22ed7264, EBX=0x00000014, ECX=0xe59811c0, EDX=0x00000001
ESP=0x02f9f494, EBP=0xffa0a0a0, ESI=0x00000008, EDI=0x000003fc
EIP=0x6d0391ac, EFLAGS=0x00010286
Top of Stack: (sp=0x02f9f494)
0x02f9f494: 02f9f4f0 00000001 02f9f574 00000014
0x02f9f4a4: 6d0aaa4e 22ed7264 e59811c0 00000001
0x02f9f4b4: 00000014 02f9f6f0 02f9f4f0 00000000
0x02f9f4c4: 00000000 00000001 02bc8c18 00000100
0x02f9f4d4: 03a89000 00000400 e59811c0 00000000
0x02f9f4e4: 00000000 00000001 00000014 00000000
0x02f9f4f4: 00000000 00000001 00000014 00000000
0x02f9f504: 00000000 00000004 00000400 00000000
Instructions: (pc=0x6d0391ac)
0x6d03919c: 00 00 00 00 8b 54 24 1c 8b 28 81 cd 00 00 00 ff
0x6d0391ac: 89 29 83 c0 04 83 c1 04 4a 75 ed 03 c6 03 cf 4b
Stack: [0x02f50000,0x02fa0000], sp=0x02f9f494, free space=317k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C [awt.dll+0x391ac]
[error occurred during error reporting (printing native stack), id 0xc0000005]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j sun.awt.windows.WToolkit.eventLoop()V+0
j sun.awt.windows.WToolkit.run()V+69
j java.lang.Thread.run()V+11
v ~StubRoutines::call_stub
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x0370e400 JavaThread "D3D Screen Updater" daemon [_thread_blocked, id=2768, stack(0x034d0000,0x03520000)]
0x031a4400 JavaThread "Thread-6" daemon [_thread_blocked, id=1424, stack(0x03610000,0x03660000)]
0x03113800 JavaThread "AWT-EventQueue-0" [_thread_in_native, id=3532, stack(0x03540000,0x03590000)]
0x03113c00 JavaThread "AWT-Shutdown" [_thread_blocked, id=4540, stack(0x035a0000,0x035f0000)]
0x03119000 JavaThread "Keep-Alive-Timer" daemon [_thread_blocked, id=2816, stack(0x02f00000,0x02f50000)]
=>0x02bbf800 JavaThread "AWT-Windows" daemon [_thread_in_native, id=5620, stack(0x02f50000,0x02fa0000)]
0x02bbc400 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=5272, stack(0x02eb0000,0x02f00000)]
0x02b38c00 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=5224, stack(0x02db0000,0x02e00000)]
0x02b32800 JavaThread "CompilerThread0" daemon [_thread_blocked, id=1268, stack(0x02d60000,0x02db0000)]
0x02b31000 JavaThread "Attach Listener" daemon [_thread_blocked, id=1316, stack(0x02d10000,0x02d60000)]
0x02b2fc00 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=5876, stack(0x02cc0000,0x02d10000)]
0x02af1000 JavaThread "Finalizer" daemon [_thread_blocked, id=1128, stack(0x02c70000,0x02cc0000)]
0x02aec400 JavaThread "Reference Handler" daemon [_thread_blocked, id=3152, stack(0x02c20000,0x02c70000)]
0x00886400 JavaThread "main" [_thread_in_native, id=5336, stack(0x00910000,0x00960000)]
Other Threads:
0x02aeac00 VMThread [stack: 0x02bd0000,0x02c20000] [id=6084]
0x02b4c800 WatcherThread [stack: 0x02e00000,0x02e50000] [id=2064]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 1984K, used 204K [0x22990000, 0x22bb0000, 0x22e70000)
eden space 1792K, 0% used [0x22990000, 0x22993f20, 0x22b50000)
from space 192K, 98% used [0x22b80000, 0x22baf2a8, 0x22bb0000)
to space 192K, 0% used [0x22b50000, 0x22b50000, 0x22b80000)
tenured generation total 25940K, used 15561K [0x22e70000, 0x247c5000, 0x26990000)
the space 25940K, 59% used [0x22e70000, 0x23da26f8, 0x23da2800, 0x247c5000)
compacting perm gen total 12288K, used 2704K [0x26990000, 0x27590000, 0x2a990000)
the space 12288K, 22% used [0x26990000, 0x26c34128, 0x26c34200, 0x27590000)
ro space 8192K, 63% used [0x2a990000, 0x2aea8b20, 0x2aea8c00, 0x2b190000)
rw space 12288K, 53% used [0x2b190000, 0x2b805138, 0x2b805200, 0x2bd90000)
Dynamic libraries:
0x00400000 - 0x00424000 C:\Program Files\Java\jre6\bin\javaw.exe
0x7c910000 - 0x7c9c9000 C:\WINDOWS\system32\ntdll.dll
0x7c800000 - 0x7c906000 C:\WINDOWS\system32\kernel32.dll
0x77da0000 - 0x77e4c000 C:\WINDOWS\system32\ADVAPI32.dll
0x77e50000 - 0x77ee2000 C:\WINDOWS\system32\RPCRT4.dll
0x77fc0000 - 0x77fd1000 C:\WINDOWS\system32\Secur32.dll
0x7e390000 - 0x7e421000 C:\WINDOWS\system32\USER32.dll
0x77ef0000 - 0x77f39000 C:\WINDOWS\system32\GDI32.dll
0x5cea0000 - 0x5cec6000 C:\WINDOWS\system32\ShimEng.dll
0x715c0000 - 0x71639000 C:\WINDOWS\AppPatch\AcLayers.DLL
0x7c9d0000 - 0x7d1f5000 C:\WINDOWS\system32\SHELL32.dll
0x77be0000 - 0x77c38000 C:\WINDOWS\system32\msvcrt.dll
0x77f40000 - 0x77fb6000 C:\WINDOWS\system32\SHLWAPI.dll
0x774a0000 - 0x775dd000 C:\WINDOWS\system32\ole32.dll
0x76960000 - 0x76a16000 C:\WINDOWS\system32\USERENV.dll
0x72f50000 - 0x72f76000 C:\WINDOWS\system32\WINSPOOL.DRV
0x76320000 - 0x7633d000 C:\WINDOWS\system32\IMM32.DLL
0x77390000 - 0x77493000 C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.5512_x-ww_35d4ce83\comctl32.dll
0x7c340000 - 0x7c396000 C:\Program Files\Java\jre6\bin\msvcr71.dll
0x6d800000 - 0x6da8b000 C:\Program Files\Java\jre6\bin\client\jvm.dll
0x76ae0000 - 0x76b0f000 C:\WINDOWS\system32\WINMM.dll
0x6d7b0000 - 0x6d7bc000 C:\Program Files\Java\jre6\bin\verify.dll
0x6d330000 - 0x6d34f000 C:\Program Files\Java\jre6\bin\java.dll
0x6d290000 - 0x6d298000 C:\Program Files\Java\jre6\bin\hpi.dll
0x76ba0000 - 0x76bab000 C:\WINDOWS\system32\PSAPI.DLL
0x6d7f0000 - 0x6d7ff000 C:\Program Files\Java\jre6\bin\zip.dll
0x6d000000 - 0x6d14a000 C:\Program Files\Java\jre6\bin\awt.dll
0x5b090000 - 0x5b0c8000 C:\WINDOWS\system32\uxtheme.dll
0x6d230000 - 0x6d284000 C:\Program Files\Java\jre6\bin\fontmanager.dll
0x10000000 - 0x1001d000 C:\Program Files\SlySoft\AnyDVD\ADvdDiscHlp.dll
0x74690000 - 0x746dc000 C:\WINDOWS\system32\MSCTF.dll
0x77b50000 - 0x77b72000 C:\WINDOWS\system32\apphelp.dll
0x75140000 - 0x7516e000 C:\WINDOWS\system32\msctfime.ime
0x4fcf0000 - 0x4fe96000 C:\WINDOWS\system32\d3d9.dll
0x6de60000 - 0x6de66000 C:\WINDOWS\system32\d3d8thk.dll
0x77bd0000 - 0x77bd8000 C:\WINDOWS\system32\VERSION.dll
0x03290000 - 0x03335000 C:\Documents and Settings\Michel Marcoux\Application Data\LANCITE\EPhoto\EPhotoWin.dll
0x6d610000 - 0x6d623000 C:\Program Files\Java\jre6\bin\net.dll
0x719f0000 - 0x71a07000 C:\WINDOWS\system32\WS2_32.dll
0x719e0000 - 0x719e8000 C:\WINDOWS\system32\WS2HELP.dll
0x71990000 - 0x719d0000 C:\WINDOWS\System32\mswsock.dll
0x76ed0000 - 0x76ef7000 C:\WINDOWS\system32\DNSAPI.dll
0x76f60000 - 0x76f68000 C:\WINDOWS\System32\winrnr.dll
0x76f10000 - 0x76f3d000 C:\WINDOWS\system32\WLDAP32.dll
0x76f70000 - 0x76f76000 C:\WINDOWS\system32\rasadhlp.dll
0x68000000 - 0x68036000 C:\WINDOWS\system32\rsaenh.dll
0x6fee0000 - 0x6ff35000 C:\WINDOWS\system32\netapi32.dll
0x6d790000 - 0x6d798000 C:\Program Files\Java\jre6\bin\sunmscapi.dll
0x779e0000 - 0x77a77000 C:\WINDOWS\system32\CRYPT32.dll
0x77a80000 - 0x77a92000 C:\WINDOWS\system32\MSASN1.dll
0x62e40000 - 0x62e99000 C:\WINDOWS\system32\hnetcfg.dll
0x719d0000 - 0x719d8000 C:\WINDOWS\System32\wshtcpip.dll
0x778e0000 - 0x779d8000 C:\WINDOWS\system32\SETUPAPI.dll
0x6d630000 - 0x6d639000 C:\Program Files\Java\jre6\bin\nio.dll
0x770e0000 - 0x7716b000 C:\WINDOWS\system32\OLEAUT32.DLL
VM Arguments:
java_command: ephoto.jMain @https @iphoto.jeancoutu.com @-1 @PJC @FRN @PHS @{5D457962-F699-4D4C-980D-1DF228BE6F68} @/Page/
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=C:\Program Files\Internet Explorer;;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\Fichiers communs\Ahead\Lib\;C:\Program Files\Fichiers communs\Ahead\Lib\
USERNAME=Michel Marcoux
OS=Windows_NT
PROCESSOR_IDENTIFIER=x86 Family 15 Model 4 Stepping 9, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows XP Build 2600 Service Pack 3
CPU:total 1 (1 cores per cpu, 1 threads per core) family 15 model 4 stepping 9, cmov, cx8, fxsr, mmx, sse, sse2, sse3
Memory: 4k page, physical 1572336k(800256k free), swap 3513288k(2538056k free)
vm_info: Java HotSpot(TM) Client VM (14.3-b01) for windows-x86 JRE (1.6.0_17-b04), built on Oct 11 2009 00:52:06 by "java_re" with MS VC++ 7.1
time: Fri Jan 08 19:23:51 2010
elapsed time: 8 seconds
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x6d0391ac, pid=4120, tid=4744
Current thread (0x03187000): JavaThread "AWT-Windows" daemon [_thread_in_native, id=4744, stack(0x03420000,0x03470000)]
siginfo: ExceptionCode=0xc0000005, writing address 0xe59c1300
Registers:
EAX=0x230b0724, EBX=0x00000100, ECX=0xe59c1300, EDX=0x00000100
ESP=0x0346f294, EBP=0xffffffff, ESI=0x00000a0c, EDI=0x00000000
Top of Stack: (sp=0x0346f294)
0x0346f294: 0346f2f0 00000100 0346f374 00000100
0x0346f2a4: 6d0aaa4e 230b0724 e59c1300 00000100
0x0346f2b4: 00000100 0346f4f0 0346f2f0 00000000
0x0346f2c4: 00000000 00000100 02af32b0 00000100
0x0346f2d4: 0014cc40 00000400 e59c1300 00000000
0x0346f2e4: 00000000 00000100 00000100 00000000
0x0346f2f4: 00000000 00000100 00000100 00000000
0x0346f304: 00000000 00000004 00000400 00000000
Stack: [0x03420000,0x03470000], sp=0x0346f294, free space=316k
C [awt.dll+0x391ac]
0x032ed000 JavaThread "Thread-11" [_thread_in_native, id=6048, stack(0x03a10000,0x03a60000)]
0x031d9000 JavaThread "D3D Screen Updater" daemon [_thread_blocked, id=5100, stack(0x038d0000,0x03920000)]
0x031de400 JavaThread "thread applet-ephoto.jStart.class-1" [_thread_blocked, id=5112, stack(0x03880000,0x038d0000)]
0x031be000 JavaThread "AWT-EventQueue-2" [_thread_in_native, id=1148, stack(0x03830000,0x03880000)]
0x031b1400 JavaThread "Applet 1 LiveConnect Worker Thread" [_thread_blocked, id=4420, stack(0x03790000,0x037e0000)]
0x031bb400 JavaThread "Browser Side Object Cleanup Thread" [_thread_blocked, id=5076, stack(0x03740000,0x03790000)]
0x031ac000 JavaThread "Windows Tray Icon Thread" [_thread_in_native, id=4728, stack(0x03680000,0x036d0000)]
0x031a9c00 JavaThread "CacheCleanUpThread" daemon [_thread_blocked, id=4368, stack(0x03630000,0x03680000)]
0x03191400 JavaThread "CacheMemoryCleanUpThread" daemon [_thread_blocked, id=816, stack(0x03590000,0x035e0000)]
0x0318d800 JavaThread "AWT-EventQueue-0" [_thread_blocked, id=4660, stack(0x035e0000,0x03630000)]
0x03189c00 JavaThread "Java Plug-In Heartbeat Thread" [_thread_blocked, id=3948, stack(0x03540000,0x03590000)]
=>0x03187000 JavaThread "AWT-Windows" daemon [_thread_in_native, id=4744, stack(0x03420000,0x03470000)]
0x03185800 JavaThread "AWT-Shutdown" [_thread_blocked, id=5048, stack(0x033d0000,0x03420000)]
0x03181400 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=5492, stack(0x03380000,0x033d0000)]
0x02bcb400 JavaThread "Java Plug-In Pipe Worker Thread (Client-Side)" daemon [_thread_in_native, id=5196, stack(0x030d0000,0x03120000)]
0x02bc6c00 JavaThread "traceMsgQueueThread" daemon [_thread_blocked, id=5716, stack(0x03030000,0x03080000)]
0x02b4e400 JavaThread "Timer-0" [_thread_blocked, id=924, stack(0x02fe0000,0x03030000)]
0x02b39400 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=1840, stack(0x02db0000,0x02e00000)]
0x02b32c00 JavaThread "CompilerThread0" daemon [_thread_blocked, id=5132, stack(0x02d60000,0x02db0000)]
0x02b31400 JavaThread "Attach Listener" daemon [_thread_blocked, id=4560, stack(0x02d10000,0x02d60000)]
0x02b30000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=2904, stack(0x02cc0000,0x02d10000)]
0x02af1400 JavaThread "Finalizer" daemon [_thread_blocked, id=2560, stack(0x02c70000,0x02cc0000)]
0x02aecc00 JavaThread "Reference Handler" daemon [_thread_blocked, id=3140, stack(0x02c20000,0x02c70000)]
0x00886800 JavaThread "main" [_thread_blocked, id=5092, stack(0x00910000,0x00960000)]
Other Threads:
0x02aeb400 VMThread [stack: 0x02bd0000,0x02c20000] [id=2828]
0x02b4cc00 WatcherThread [stack: 0x02e00000,0x02e50000] [id=3792]
Heap
def new generation total 960K, used 576K [0x22990000, 0x22a90000, 0x22e70000)
eden space 896K, 64% used [0x22990000, 0x22a203c8, 0x22a70000)
from space 64K, 0% used [0x22a80000, 0x22a80000, 0x22a90000)
to space 64K, 0% used [0x22a70000, 0x22a70000, 0x22a80000)
tenured generation total 6204K, used 4412K [0x22e70000, 0x2347f000, 0x26990000)
the space 6204K, 71% used [0x22e70000, 0x232bf348, 0x232bf400, 0x2347f000)
compacting perm gen total 12288K, used 4495K [0x26990000, 0x27590000, 0x2a990000)
the space 12288K, 36% used [0x26990000, 0x26df3c70, 0x26df3e00, 0x27590000)
Dynamic libraries:
0x00400000 - 0x00424000 C:\Program Files\Java\jre6\bin\java.exe
0x6d430000 - 0x6d436000 C:\Program Files\Java\jre6\bin\jp2native.dll
0x6d1d0000 - 0x6d1e3000 C:\Program Files\Java\jre6\bin\deploy.dll
0x770e0000 - 0x7716b000 C:\WINDOWS\system32\OLEAUT32.dll
0x404a0000 - 0x40586000 C:\WINDOWS\system32\WININET.dll
0x02e50000 - 0x02e59000 C:\WINDOWS\system32\Normaliz.dll
0x45180000 - 0x452b2000 C:\WINDOWS\system32\urlmon.dll
0x40b40000 - 0x40d28000 C:\WINDOWS\system32\iertutil.dll
0x6d6b0000 - 0x6d6f3000 C:\Program Files\Java\jre6\bin\regutils.dll
0x7d200000 - 0x7d4bc000 C:\WINDOWS\system32\msi.dll
VM Arguments:
jvm_args: -D__jvm_launched=16232872943 -Xbootclasspath/a:C:\PROGRA~1\Java\jre6\lib\deploy.jar;C:\PROGRA~1\Java\jre6\lib\javaws.jar;C:\PROGRA~1\Java\jre6\lib\plugin.jar
java_command: sun.plugin2.main.client.PluginMain write_pipe_name=jpi2_pid4388_pipe3,read_pipe_name=jpi2_pid4388_pipe2
OS=Windows_NT
Memory: 4k page, physical 1572336k(803608k free), swap 3513288k(2538688k free)
time: Fri Jan 08 19:23:59 2010
elapsed time: 22 seconds
