chris-65
14 messages
Le 19 Janvier 2022 à 10h01
J'ai désactivé les programmes en rouge :
Pour information, j'ai contrôlé le temps de démarrage et celui de fermeture de Windows.
Démarrage : 1 minute 30 secondes
Fermeture : 1 minute 45 secondes
Non HKCU:Run SUPERAntiSpyware SUPERAntiSpyware C:\Program Files\SUPERAntiSpyware\SUPERAntiSpyware.exe
Non HKCU:Run Syncables C:\Program Files (x86)\syncables\syncables desktop\Syncables.exe
Non HKLM:Run Adobe ARM Adobe Inc. "C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe"
Non HKLM:Run AmIcoSinglun64 AlcorMicro Co., Ltd. C:\Program Files (x86)\AmIcoSingLun\AmIcoSinglun64.exe
Non HKLM:Run ASUS Screen Saver Protector ASUS C:\Windows\AsScrPro.exe
Non HKLM:Run ASUS WebStorage
Non HKLM:Run ATKMEDIA ASUS C:\Program Files (x86)\ASUS\ATK Media\DMedia.exe
Non HKLM:Run ATKOSD2 ASUS C:\Program Files (x86)\ASUS\ATKOSD2\ATKOSD2.exe
Oui HKLM:Run Bdagent Bitdefender "C:\Program Files\Bitdefender\Bitdefender Security\bdagent.exe"
Oui HKLM:Run BdVpnApp Bitdefender "C:\Program Files\Bitdefender\Bitdefender VPN\BdVpnApp.exe" startup
Non HKLM:Run Boingo Wi-Fi
Non HKLM:Run CLMLServer
Oui HKLM:Run ETDCtrl ELAN Microelectronics Corp. %ProgramFiles%\Elantech\ETDCtrl.exe
Non HKLM:Run ETDWare ELAN Microelectronics Corp. %ProgramFiles%\Elantech\ETDCtrl.exe
Non HKLM:Run HControlUser ASUS C:\Program Files (x86)\ASUS\ATK Hotkey\HControlUser.exe
Oui HKLM:Run HotKeysCmds Intel Corporation C:\Windows\system32\hkcmd.exe
Oui HKLM:Run IgfxTray Intel Corporation C:\Windows\system32\igfxtray.exe
Non HKLM:Run Logitech Download Assistant Microsoft Corporation C:\Windows\system32\rundll32.exe C:\Windows\System32\LogiLDA.dll,LogiFetch
Non HKLM:Run NvCplDaemon Microsoft Corporation RUNDLL32.EXE C:\Windows\system32\NvCpl.dll,NvStartup
Oui HKLM:Run Persistence Intel Corporation C:\Windows\system32\igfxpers.exe
Non HKLM:Run RemoteControl9 "C:\Program Files (x86)\Cyberlink\PowerDVD9\PDVD9Serv.exe"
Non HKLM:Run RtHDVCpl Realtek Semiconductor C:\Program Files\Realtek\Audio\HDA\RAVCpl64.exe -s
Non HKLM:Run UpdateLBPShortCut "C:\Program Files (x86)\CyberLink\LabelPrint\MUITransfer\MUIStartMenu.exe" "C:\Program Files (x86)\CyberLink\LabelPrint" UpdateWithCreateOnce "Software\CyberLink\LabelPrint\2.5"
Non HKLM:Run UpdateP2GoShortCut
Non HKLM:Run UpdatePSTShortCut "C:\Program Files (x86)\Cyberlink\DVD Suite\MUITransfer\MUIStartMenu.exe" "C:\Program Files (x86)\Cyberlink\DVD Suite" UpdateWithCreateOnce "Software\CyberLink\PowerStarter"
Non Startup Common FancyStart daemon.lnk C:\Windows\INSTAL~1\{2B818~1\_C4A2F~1.EXE
Non Startup Common SRS Premium Sound.lnk Acresso Software Inc. C:\Windows\INSTAL~1\{E5CF6~1\NEWSHO~4.EXE
Publicité |
28245 messages
Le 21 Janvier 2022 à 07h54
Hello,
je ne connais pas les paramètres avant, observes-tu une amélioration ?
chris-65
14 messages
Le 21 Janvier 2022 à 09h06
28245 messages
Le 26 Janvier 2022 à 08h04
chris-65
14 messages
Le 26 Janvier 2022 à 17h36
bonjour,
Ok, je vais essayer de faire un nettoyage de l'intérieur du pc , des connecteurs et du ventilateur.
j'en profiterais pour voir si je ne vois rien de bizarre sur les composants.
Merci.
28245 messages
Le 27 Janvier 2022 à 10h02
Hello la seule chose qui est invisible
C'est la poussiere de l'alimentation.
chris-65
14 messages
Le 30 Janvier 2022 à 10h40
Bon ! j'ai ouvert mon PC pour le nettoyer ( un bon coup de soufflette air comprimé partout ).
Je n'ai rien vu de bizarre au niveaux des composants de la carte.
J'en ai profité pour changer la pile du bios.
j'ai toujours le même problème de démarrage à froid, donc je pense que quand ça lâchera, il n'y aura plus qu'à changer de Pc
https://postimg.cc/30v1HfMz
https://postimg.cc/Mv15PLmQ
https://postimg.cc/gnyyqZGy
Merci pour les conseils et votre aide.
28245 messages
Le 31 Janvier 2022 à 13h04
Hello
Il y a combien de RAM sur ce PC ?
chris-65
14 messages
Le 01 Février 2022 à 08h45
Il y a 4 go de ram ( 2 barrettes de 2 Go )
J'ai fait un test sur la ram avec l'outil de diagnostic de mémoire Windows.( ras )
J'ai aussi testé " physiquement " chacune des deux barrettes.
_J'ai démarré le Pc avec une seule barrette testé sur chaque slot de ram pour voir si une barrette était HS ou si un slot de ram était HS.
_Le Pc à démarré ( à chaud bien sûr! ) à chaque fois avec une seule barrette mémoire.
C'est pourquoi je ne pense pas que cela vienne de la ram.
28245 messages
Le 02 Février 2022 à 09h52
Hello, parfait c'est suffisant pour ton PC, bonne idée pour les test !
Techniquement la seule chose chose qui resterait à faire est de changer la pâte thermique.
Mais je ne crois pas que le problème vienne de là, il suffirait d'une micro soudure entrain de lâcher sur un condensateur, dans l'alimentation ou sur la carte mère, mais je penche sur l'alimentation. J'ai déjà vu un PC dont le câble d'alimentation était défectueux, et/ou la prise femelle de l'alimentation. Ce qui peut arriver aussi, c'est le micro bouton ON/OFF de l'alimentation ( derrière le PC ) qui fait des siennes !
chris-65
14 messages
Le 02 Février 2022 à 10h51
Bonjour !
D'accord !
J'aurais une dernière question.
Est ce que l'alimentation en électricité passe par le même endroit ( le même composant ) selon que le Pc soit alimenté par le câble secteur ou seulement par la batterie ?
Car, que je démarre sur le secteur ( sans batterie dans le pc ) ou seulement sur la batterie ( sans câble secteur branché ), j'ai le même problème.
28245 messages
Le 03 Février 2022 à 09h07
Hello, ,
Pour les Pc portables l'avantage est qu'ils peuvent démarrer sans la batterie, mais cela comporte un risque énorme en cas de coupure de courant, cela va faire des erreurs de disques immanquablement ! Donc pour un portable je ne conseille pas d'enlever la batterie ! Je viens de penser à une chose, tu gagnerais de la rapidité en faisant mettre un SSD, du moins si tu es branché en SATA sur le disque actuel. Les prix sont raisonnables en ce moment.
chris-65
14 messages
Le 03 Février 2022 à 10h08
D'accord, je te remercie pour l'aide apportée.
Je ne manquerais pas de revenir sur le site si j'ai d'autres soucis.
Merci.
28245 messages
Le 05 Février 2022 à 09h55
Hello,
