Vérification de mon PC demandée par Winx
Forum informatique > Aide Virus, Spywares et autres logiciels malveillants > Vérification de mon PC demandée par Winx
[Page 4 sur 4 - 55 messages]
miclau
Avatar de miclau
235 messages
Lien direct Le 18 Mai 2018 à 20h18
Hello, hi, bonsoir Winx
Je pense avoir enfin trouvé c'est de ma faute je ne lis pas assez, enfin je te joins ce fichier.
Merci encore et mes excuses
Miclau
Non EPLTarget
Non HKCU:Run Avanquest Message Avanquest Software "C:\Users\michel\AppData\Local\Avanquest\Avanquest Message\AQNotif.exe"
Non HKCU:Run CCleaner Monitoring Piriform Ltd "C:\Program Files\CCleaner\CCleaner64.exe" /MONITOR
Non HKCU:Run FreeMi UPnP Media Server Stéphane Mitermite C:\Program Files\FreeMi UPnP Media Server\FreeMi UPnP Media Server.exe
Oui HKCU:Run Gadwin PrintScreen Gadwin Systems, Inc "C:\Program Files (x86)\Gadwin Systems\PrintScreen\PrintScreen.exe" /nosplash
Oui HKCU:Run Google Update C:\Users\michel\AppData\Local\Google\Update\1.3.33.7\GoogleUpdateCore.exe
Non HKCU:Run RadioSure TheBestWare Studio C:\Users\michel\AppData\Local\RadioSure\RadioSure.exe /hidden
Non HKCU:Run Scan Buttons NewSoft Technology Corporation C:\Program Files (x86)\NewSoft\Presto! PageManager 9.03\Pmsb.exe /M=HIDE
Non HKCU:Run SFR Mediacenter SFR "C:\Program Files (x86)\SFR\Mediacenter Evolution\MediaCenter.exe" /tray
Non HKCU:Run Spybot-S&D Cleaning "C:\Program Files (x86)\Spybot - Search & Destroy 2\SDCleaner.exe" /autoclean
Oui HKCU:Run swg Google Inc. "C:\Program Files (x86)\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe"
Oui HKCU:Run TomTomHOME.exe TomTom "C:\Program Files (x86)\TomTom HOME 2\TomTomHOMERunner.exe" -s
Oui HKLM:Run Easybits Recovery EasyBits Software AS C:\Program Files (x86)\EasyBits For Kids\ezRecover.exe
Non HKLM:Run FUFAXRCV SEIKO EPSON CORPORATION "C:\Program Files (x86)\Epson Software\FAX Utility\FUFAXRCV.exe"
Non HKLM:Run FUFAXSTM SEIKO EPSON CORPORATION "C:\Program Files (x86)\Epson Software\FAX Utility\FUFAXSTM.exe"
Non HKLM:Run HP Software Update Hewlett-Packard c:\Program Files (x86)\HP\HP Software Update\HPWuSchd2.exe
Oui HKLM:Run HPSYSDRV Hewlett-Packard C:\Program Files (x86)\Hewlett-Packard\HP Odometer\HPSYSDRV.EXE
Oui HKLM:Run LaunchHPOSIAPP Hewlett-Packard C:\Program Files (x86)\Hewlett-Packard\HP Keyboard\LaunchApp.exe
Oui HKLM:Run LogitechQuickCamRibbon Logitech Inc "C:\Program Files\Logitech\Logitech WebCam Software\LWS.exe" /hide
Oui HKLM:Run Magic Desktop for HP notification Easybits "C:\ProgramData\Easybits Magic Desktop for HP\mdhpSUN.exe"
Non HKLM:Run PMSpeed NewSoft Technology Corporation C:\Program Files (x86)\NewSoft\Presto! PageManager 9.03\PMSpeed.EXE
Oui HKLM:Run SecurityHealth Microsoft Corporation %ProgramFiles%\Windows Defender\MSASCuiL.exe
Oui HKLM:Run SunJavaUpdateSched Oracle Corporation "C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe"
Oui HKLM:Run Windows Mobile Device Center Microsoft Corporation %windir%\WindowsMobile\wmdc.exe
Oui HKLM:Run WrtMon.exe NewSoft Technology Corporation C:\windows\system32\spool\drivers\x64\3\WrtMon.exe
Oui Startup Common FAH.lnk Nico Mak Computing C:\Program Files\WinZip\FAH\FAHConsole.exe
Oui Startup Common Microsoft Office.lnk Microsoft Corporation C:\Program Files (x86)\Microsoft Office\Office\OSA9.EXE
Non Startup Common Ralink Wireless Utility.lnk Ralink Technology, Inc. C:\Program Files (x86)\Ralink\Common\RaWiFi.exe
Oui Startup User Event Reminder.lnk C:\pmw\PMREMIND.EXE
Non Startup User La Chaîne Météo.lnk C:\Program Files (x86)\LACHAN~1\LACHAN~1.EXE
Non Startup User Lanceur Pointsoft.lnk C:\POINTS~1\lanceur.exe
Oui Startup User Outil de notification de cadeaux MSN.lnk Microsoft Corporation C:\Users\michel\AppData\Roaming\Microsoft\Outil de notification de cadeaux MSN\msnotif.exe
28042 messages
En ligne
Lien direct Le 19 Mai 2018 à 18h10
relance CCleaner
va dans Outils/démarrage
va sur chaque ligne que j'ai mise en rouge, et "Désactive" ( pas supprimé Choqué )
Redémarre ton PC.....il devrait être un plus vif au démarrage
note:
cette action ne supprime pas le programme, mais empêche le démarrage de trop d'applications au lancement du PC....on peut toujours les lancer manuellement en cas de besoins.
Sourire
miclau
Avatar de miclau
235 messages
Lien direct Le 20 Mai 2018 à 18h14
Hello, Hi, bonjour Winx
C'est fait j'ai désactivé comme tu m'as dit, excuses-moi j'ai pas pu te prévenir hier mais j'ai eu un imprévu, je suis rentré ce soir.
Je suis donc là pour la suite avec mes remerciements anticipés.
Bonne soirée
Miclau
28042 messages
En ligne
Lien direct Le 21 Mai 2018 à 10h37
télécharge l'outil SuperAntiSpyware sur ton bureau.
Lance le fichier d'install, mais attention de décocher les deux cases suivantes
Ensuite tu clic d'abord sur la mise à jour de la base de donnée ( Clic here to check for update ), tu devras cliquer sur "continue" une fois la lise à jour terminée.
Lance ensuite le scan rapide de ta machine.
tu auras ceci en cs de détections
En fin de scan tu clic sur "Continue"
Poste le rapport de suppression
clic sur le bouton System Tools / --->> Scan log>>> là tu as acèès au rapport de scan ( log ) poste le rapport sur le forum.
miclau
Avatar de miclau
235 messages
Lien direct Le 21 Mai 2018 à 13h00
Hello, Hi, Bonjour Winx
Je te joins le rapport qui n'était pas du tout comme celui de l'exemple, mais je pense avoir bien fait.
Bonne journée et merci de ton aide
Cordialement
Miclau
SUPERAntiSpyware Scan Log
http://www.superantispyware.com
Generated 05/21/2018 at 12:44 PM
Application Version : 6.0.1250
Database Version : 14685
Scan type : Complete Scan
Total Scan Time : 00:41:46
Operating System Information
Windows 10 Home 64-bit (Build 10.00.16299)
UAC On - Administrator
Memory items scanned : 1086
Memory items detected : 0
Registry items scanned : 76138
Registry items detected : 0
File items scanned : 38136
File items detected : 69
Adware.Tracking Cookie
C:UsersmichelAppDataLocalMicrosoftWindowsINetCookiesdeprecated.cookieC:UsersmichelAppDataLocalMicrosoftWindowsINetCookiesdeprecated.cookie [ /ads.stickyadstv.com ]
scorecardresearch.com/.UID [ C:USERSMICHELAPPDATALOCALPACKAGESMICROSOFT.BINGWEATHER_8WEKYB3D8BBWEACINETCOOKIES47ZJZNSQ.TXT ]
estat.com/.e [ C:USERSMICHELAPPDATALOCALPACKAGESMICROSOFT.BINGWEATHER_8WEKYB3D8BBWEACINETCOOKIES89MYBYBB.TXT ]
cdn.at.atwola.com/.msnping [ C:USERSMICHELAPPDATALOCALPACKAGESMICROSOFT.BINGWEATHER_8WEKYB3D8BBWEACINETCOOKIESH0YTFDLW.TXT ]
at.atwola.com/.ATTACID [ C:USERSMICHELAPPDATALOCALPACKAGESMICROSOFT.BINGWEATHER_8WEKYB3D8BBWEACINETCOOKIESMQV130YC.TXT ]
at.atwola.com/.dmpsync [ C:USERSMICHELAPPDATALOCALPACKAGESMICROSOFT.BINGWEATHER_8WEKYB3D8BBWEACINETCOOKIESMQV130YC.TXT ]
advertising.com/.APID [ C:USERSMICHELAPPDATALOCALPACKAGESMICROSOFT.BINGWEATHER_8WEKYB3D8BBWEACINETCOOKIESNHFD1M51.TXT ]
advertising.com/.DOMSYNC [ C:USERSMICHELAPPDATALOCALPACKAGESMICROSOFT.BINGWEATHER_8WEKYB3D8BBWEACINETCOOKIESNHFD1M51.TXT ]
advertising.com/.IDSYNC [ C:USERSMICHELAPPDATALOCALPACKAGESMICROSOFT.BINGWEATHER_8WEKYB3D8BBWEACINETCOOKIESNHFD1M51.TXT ]
.doubleclick.net [ C:USERSMICHELAPPDATAROAMINGMOZILLAFIREFOXPROFILES3WXNGHZY.DEFAULT-1488806557634-1523552075614COOKIES.SQLITE ]
.avid-adserver.com [ C:USERSMICHELAPPDATAROAMINGMOZILLAFIREFOXPROFILES3WXNGHZY.DEFAULT-1488806557634-1523552075614COOKIES.SQLITE ]
.bidswitch.net [ C:USERSMICHELAPPDATAROAMINGMOZILLAFIREFOXPROFILES3WXNGHZY.DEFAULT-1488806557634-1523552075614COOKIES.SQLITE ]
.ctnsnet.com [ C:USERSMICHELAPPDATAROAMINGMOZILLAFIREFOXPROFILES3WXNGHZY.DEFAULT-1488806557634-1523552075614COOKIES.SQLITE ]
banner2.cookappsgames.com [ C:USERSMICHELAPPDATAROAMINGMOZILLAFIREFOXPROFILES3WXNGHZY.DEFAULT-1488806557634-1523552075614COOKIES.SQLITE ]
.googleadservices.com [ C:USERSMICHELAPPDATAROAMINGMOZILLAFIREFOXPROFILESLWT55P65.DEFAULT-1488806557634-1505679815787COOKIES.SQLITE ]
.advertising.com [ C:USERSMICHELAPPDATAROAMINGMOZILLAFIREFOXPROFILESLWT55P65.DEFAULT-1488806557634-1505679815787COOKIES.SQLITE ]
.atdmt.com [ C:USERSMICHELAPPDATAROAMINGMOZILLAFIREFOXPROFILESLWT55P65.DEFAULT-1488806557634-1505679815787COOKIES.SQLITE ]
.btrll.com [ C:USERSMICHELAPPDATAROAMINGMOZILLAFIREFOXPROFILESLWT55P65.DEFAULT-1488806557634-1505679815787COOKIES.SQLITE ]
.casalemedia.com [ C:USERSMICHELAPPDATAROAMINGMOZILLAFIREFOXPROFILESLWT55P65.DEFAULT-1488806557634-1505679815787COOKIES.SQLITE ]
.connexity.net [ C:USERSMICHELAPPDATAROAMINGMOZILLAFIREFOXPROFILESLWT55P65.DEFAULT-1488806557634-1505679815787COOKIES.SQLITE ]
www.googleadservices.com [ C:USERSMICHELAPPDATAROAMINGMOZILLAFIREFOXPROFILESLWT55P65.DEFAULT-1488806557634-1505679815787COOKIES.SQLITE ]
.doubleclick.net [ C:USERSMICHELAPPDATAROAMINGMOZILLAFIREFOXPROFILESLWT55P65.DEFAULT-1488806557634-1505679815787COOKIES.SQLITE ]
.adtech.de [ C:USERSMICHELAPPDATAROAMINGMOZILLAFIREFOXPROFILESLWT55P65.DEFAULT-1488806557634-1505679815787COOKIES.SQLITE ]
.pubmatic.com [ C:USERSMICHELAPPDATAROAMINGMOZILLAFIREFOXPROFILESLWT55P65.DEFAULT-1488806557634-1505679815787COOKIES.SQLITE ]
.adsrvr.org [ C:USERSMICHELAPPDATAROAMINGMOZILLAFIREFOXPROFILESLWT55P65.DEFAULT-1488806557634-1505679815787COOKIES.SQLITE ]
.tapad.com [ C:USERSMICHELAPPDATAROAMINGMOZILLAFIREFOXPROFILESLWT55P65.DEFAULT-1488806557634-1505679815787COOKIES.SQLITE ]
.scorecardresearch.com [ C:USERSMICHELAPPDATAROAMINGMOZILLAFIREFOXPROFILESLWT55P65.DEFAULT-1488806557634-1505679815787COOKIES.SQLITE ]
.adfarm1.adition.com [ C:USERSMICHELAPPDATAROAMINGMOZILLAFIREFOXPROFILESLWT55P65.DEFAULT-1488806557634-1505679815787COOKIES.SQLITE ]
.adaptv.advertising.com [ C:USERSMICHELAPPDATAROAMINGMOZILLAFIREFOXPROFILESLWT55P65.DEFAULT-1488806557634-1505679815787COOKIES.SQLITE ]
.bluekai.com [ C:USERSMICHELAPPDATAROAMINGMOZILLAFIREFOXPROFILESLWT55P65.DEFAULT-1488806557634-1505679815787COOKIES.SQLITE ]
.bidswitch.net [ C:USERSMICHELAPPDATAROAMINGMOZILLAFIREFOXPROFILESLWT55P65.DEFAULT-1488806557634-1505679815787COOKIES.SQLITE ]
.netmng.com [ C:USERSMICHELAPPDATAROAMINGMOZILLAFIREFOXPROFILESLWT55P65.DEFAULT-1488806557634-1505679815787COOKIES.SQLITE ]
.estat.com [ C:USERSMICHELAPPDATAROAMINGMOZILLAFIREFOXPROFILESLWT55P65.DEFAULT-1488806557634-1505679815787COOKIES.SQLITE ]
.rfihub.com [ C:USERSMICHELAPPDATAROAMINGMOZILLAFIREFOXPROFILESLWT55P65.DEFAULT-1488806557634-1505679815787COOKIES.SQLITE ]
.everesttech.net [ C:USERSMICHELAPPDATAROAMINGMOZILLAFIREFOXPROFILESLWT55P65.DEFAULT-1488806557634-1505679815787COOKIES.SQLITE ]
.mookie1.com [ C:USERSMICHELAPPDATAROAMINGMOZILLAFIREFOXPROFILESLWT55P65.DEFAULT-1488806557634-1505679815787COOKIES.SQLITE ]
.geo-um.btrll.com [ C:USERSMICHELAPPDATAROAMINGMOZILLAFIREFOXPROFILESLWT55P65.DEFAULT-1488806557634-1505679815787COOKIES.SQLITE ]
.rubiconproject.com [ C:USERSMICHELAPPDATAROAMINGMOZILLAFIREFOXPROFILESLWT55P65.DEFAULT-1488806557634-1505679815787COOKIES.SQLITE ]
.mathtag.com [ C:USERSMICHELAPPDATAROAMINGMOZILLAFIREFOXPROFILESLWT55P65.DEFAULT-1488806557634-1505679815787COOKIES.SQLITE ]
.oracle.112.2o7.net [ C:USERSMICHELAPPDATAROAMINGMOZILLAFIREFOXPROFILESLWT55P65.DEFAULT-1488806557634-1505679815787COOKIES.SQLITE ]
.adnxs.com [ C:USERSMICHELAPPDATAROAMINGMOZILLAFIREFOXPROFILESLWT55P65.DEFAULT-1488806557634-1505679815787COOKIES.SQLITE ]
HackTool/Gen-Reboot.Process
C:USERSMICHELDOWNLOADSPETITS JEUXKISS PINBALL MACHINEINSTALL.EXE
Unwanted Programs Detected
SlimCleaner Plus
End of Log
28042 messages
En ligne
Lien direct Le 21 Mai 2018 à 16h46
bien, il a détecté pas mal de choses Choqué
Comment se comporte le PC à ce point ?
miclau
Avatar de miclau
235 messages
Lien direct Le 21 Mai 2018 à 16h56
Je vois qu'il est plus rapide oui effectivement par contre Windows me fait des mises à jours, mais arrivé à 100% ça me marque impossible de terminer la mise à jour.Annulation des modifications et il retravaille pendant un moment pour effacer ces modifications.
Tout se fait quand je redémarre le PC mais pas à chaque fois. Autrement tout va bien et toujours pas de périphérique audio.
Voilà Winx merci pour ton aide et bonne journée
Miclau
PS) Comment enlever tout ce que tu m'as fait faire?
j'ai fait un nouveau dossier sur le bureau et j'ai tout mis à l'intérieur à savoir Malwarebytes JRT SlimCleaner Adwcleaner RogueKiller ZHPCleaner ESET Auslogic SuperAntispy merci Winx
28042 messages
En ligne
Lien direct Le 21 Mai 2018 à 21h36
désactive les mises à jour pour le moment.....j'ai déjà vu des pc fonctionnant parfaitement, et après la mis à jour, la catastrophe;
Mais une chose à la fois.
miclau
Avatar de miclau
235 messages
Lien direct Le 21 Mai 2018 à 21h58
J'ai désactivé Windows update.
Bonne fin de soirée
Miclau
28042 messages
En ligne
Lien direct Le 22 Mai 2018 à 15h28
